Bo Deadly
I have a Tascam 234. It's a cassette machine that runs at 3 3/4 ips. Supposedly it's the best of the cassette machines.
I have performed a preliminary test of each channel by recording a test signal and then looking at it in the QA400 analyzer. This is just line in to tape and then playback through line out. No DBX. Test signal was confirmed on the scope to be -10 dBV (which is 0 dB on meters) and playback was adjusted so that the QA400 read -10 dBV.
Here are the results:
How does this look for a tape machine? Is horrible or just mediocre? How would this compare to a high quality reel-to-reel? Am I 10 dB off or 20dB or what?
The manual claims playback SNR should be 52 dB without DBX, unweighted, 20-20k.
Although, I'm a little more concerned about audible transient issues. There are sudden changes in volume (DBX is out) and fluctuations in hiss. The 3rd harmonic is pretty serious.
I was going to just try to replace caps (starting with PS) and see what happens but I thought I would ask around before I burn through a bunch of electrolytics only to find that all of the issues are ultimately just limitations in trying to use a cassette / tape.
If this is worth working on, what would you do to improve performance?
Would checking oscillators, traps, demagnetizing, ... etc improve things appreciably?
Here is the schematic:
https://groupdiy.com/index.php?action=dlattach;topic=65910.0;attach=50618
