Does anyone have experience with ICEPower 125ASX2 amp modules? I have one that is going in to protect mode and continues to attempt rebooting. When I first power it on, it works for a little bit, then after a minute or so, it begins rebooting. It's not getting hot, so I don't believe it's thermal protection related. Mains voltage is clean and in range. +/-43VDC come up on the amp and the aux supply comes up +/-25VDC. No shorts on any of the MOSFETs or anything obvious.
No schematics available, so I'm not really sure where to start lifting things to isolate the PSU from the amp to see if the problem is in the supply or the amp section.
