Phil smith
Active member
Hey guys!
Assembling my Mesa Mark IIc+ clone I found some problems... with EQ sliders!
Here's my circuit diagram, which is identical to original mark II / IV:
But my eq doesn't behave as it supposes. Fortunately I got real Mesa Studio and Quad pre's with the same EQ. So I opened up Studio preamp and started to measure some resistance values (in circuit, power off).
Here's what I measured:
Test point 1:
At any slider resistance values are:
~80-100R (slider's all way up),
~13-16k (slider's at the middle),
~6.1k (slider's all way down)
Test point 2 (2nd lead attached to the chassis):
~4.8k (slider's all way up) - I think it is a value of "EQ in/out" LDR shunt resistor (in my case it should read 47k),
~15-18k (slider's at the middle),
~4.8k (slider's all way down).
So is this 50k slider not just usual linear potentiometer?
I did some research and found link to the mesa boogie official store, which says "50k pot, special taper"
https://store.mesaboogie.com/products/pot-588535-slider-50k-special-taper.html
What kind a special taper it is? Like a bell shape resistance curve - 0-50k-0?
Does anybody know any information related to this slider (datasheet, etc)?
Will appreciate any info much!
Regards,
Phil
Test point 1:
Regards,
Phil
