Opamp Labs equalizer.
Just give them a call and ask for their catalog. They have the schematic of a Model 109 EQ using the 325EQ opamp in it. (323) 934-3566 They're in Hollywood, so it shouldn't take to long to get the catalog.
It's funny you should mention Opamp Labs, I am going there later on today to pick up some inductors. http://www.opamplabs.com/87.htm
elco
[quote author="NewYorkDave"]Hey Elco, while you're there, could you ask for a datasheet for the (discontinued) model 325L limiter? I recently acquired a small batch of these, and have no data on them at all--not even pinouts. I wrote to Bel about it, but haven't received a response.[/quote]
Thats a 10-4 good buddy. :thumb:
Here's some more Opamp EQ Schematics - Two, and Three band:
http://home.mindspring.com/~redbugg/OpampEQ2.jpg
http://home.mindspring.com/~redbugg/OpAmpEQ3.jpg
Download 'em soon if you want, as I probably won't leave 'em up for long.
Dave;
Thanks for that when I saw the 109 EQ I lost it.
Bluebird I assume the 325EQ is a plugin module
like everything op-amp makes!
Cool do you have a datasheet on the 325EQ module only.
I've got a 16 ch Opamp Console that I was thinking of parting out. Maybe sell some "channel strip" kits, with a 360 mic amp/xfrmr, a 325 EQ amp with 2 band LCR assembly. No o/p xfrmrs though, as there're only four, which on the o/p busses. These would also include gain switch, the eq pots/switches, knobs, and the octal op amp sockets. I'd pull 'em out trying to keep most of the wiring intact. There'll be about a dozen available. I guess I'll have to think of a price now................hmmmmmm.
Can you crack one open? I've always wondered what was inside those cans. What VCA technique? They are old enough not to use any of the usual-suspect chips. So low-voltage and compact that a tube is highly unlikely. The specs don't look right for Opto, yet opto would explain why no external timing controls (there are plenty of N/C pins available).
Bryson,
Thanks for the link to the datasheet. It's not linked on OpAmp's main page, so I didn't know it was there.
Personally, I think it's a shame to part out unusual old consoles, but hey--it's your choice. Here's a schematic for the 12-channel version of that console:
http://music-club.rutgers.edu/headfonz/NYDave/opamplabs-1204TV.jpg
How about trying to sell it intact before resigning to part it out?
PRR,
I only have seven of the 325L, so I'm reluctant to sacrifice one to science. I'm pretty sure OpAmp modules--at least the small signal models--are potted. But perhaps Bel from OpAmp would be willing to divulge some info about what's inside, since it appears to be a discontinued product.
