sumthing, melcor comps, PRR-176, tonelux tx5-c
Baltimore
Baltimore, MD - the Charm City
Selling some things. need to get rid of this stuff, very open to offers.
Sumthing, built and working $100. I purchased this from a member here a while age. its in a case thats been painted black? XLRs on the back are female instead of male, but otherwise it works as it should, and i can swap those out if you want.
PRR-176 case, meters, and PCB. I believe this is an original version PCB. one of the meters doesn't sit at zero. case is a used one that I bought second hand, as are the meters. $100
two melcor compressors, untested, no pinout info. $75 each. API knob not included.
tonelux tx5c compressor, $375. has original box, works as it should.
