SSLtech
So... a relay driver circuit which I've whipped up at work is being put into (extremely limited) production as a 'problem solver' board.
I've been asked to provide MTBF numbers for the product for 'certification' purposes... and I have no idea how to provide meaningful numbers!
Essentially, the relay drivers are just 2N2222 transistors, with 100kΩ base pull-up resistors to +24V, common emitters and Panasonic relays in the collector leg.
Panasonic rates their relays at hundreds of thousands of cycles, but this will likely only ever see a dozen cycles in it's lifetime... the 100kΩ resistor is ¼-Watt, and ludicrously under-stressed... there are a couple of LEDs (indicating status) which are fed 24V through 10kΩ, thus equally madly under-stressed.
A handful of diodes (for back EMF) -all massively over-rated and under-stressed.
I've looked at datasheets, but I can find no indication of how to provide meaningful MTBF numbers. -All I know is that after dozens of years doing this kind of stuff, this product is so massively over-engineered and under-rated that I feel utterly certain that it will continue to work essentially forever, with no expected failures whatsoever.
Can anyone provide me with some guidance on how to provide a real-world MTBF number?
I anticipate that "the weakest link in the chain" (i.e. whichever part of the circuit has the shortest MTBF) is what I should first focus on.
