samgraysound said:
Thank you. I don't need a coupling cap between the op amp and the output jack?
You can certainly add one, and it's not a bad idea. The typical difficulty is that it'll have to be huge, since you don't know how low the load impedance will be. But, if you ever drive a transformer input, it's really good to make sure you're not stuffing DC into the primary winding of the next device. So, yes! Something like a 10-47µF high quality electrolytic (Panasonic FR series) will work fine. Too large, and the leakage of the cap will defeat the purpose, and too small and you'll suffer reduced LF response, which might not be important if the reverb output is 100% wet.
A polarized electrolytic is not absolutely correct, but in practice, a small amount of reverse bias will not cause problems. You want the voltage across the coupling cap to be low anyway, so a polarized aluminum electrolytic is not such a horrible answer, especially for a spring reverb tank return. If you want to get fancy, a 10µF metallized polypropylene will be fantastic, will provide full LF response into a 10kΩ load, and will never wear out.
Now that I'm running .tran analysis instead of .ac , I'm noticing that both these circuits run well into clipping in the mid-range. I wonder if this is part of the design, or a misprint on the schematic or what.
.tran analysis is always a great idea. While .ac does something useful, it does not show you everything that can go wrong, and can easily fool you into thinking that a circuit is stable when it is not. You need to do both, and make sure that the circuit survives a .tran analysis before you extract info from an .ac analysis.
As for your clipping, make sure you're testing something valid. Your circuit has a drive section, a reverb tank, and a reverb tank preamp / output section. I don't know what you're doing to model the reverb tank, but to determine clipping, I'd imagine you connected all three modules together and did some sort of analysis by driving the system and watching what happens at the output of the whole chain.
The problem is that modeling the reverb tank is going to be difficult since its gain and detailed behaviors are not published, much less available as a pspice subcircuit. So, you could model the reverb tank as a simple amplifier with a specific gain (i.e. loss), and then plug that between the two driving and receiving circuits.
If the reverb tank is not specified closely, you can measure it easily. Drive the tank with an oscillator and measure its output voltage. Because spring reverbs are high-Q resonators, it's wise to measure the gain/loss at a handful of frequencies in the speech band (around 1kHz), and average the gains.
Glad to see you're making progress, and report back with what you find!
