problem with my SSL 9k build (Bruno2000's project) - strange voltages
fishdrop
Muehldorf am Inn, Bavaria, Germany
Hey guys,
is here anybody familiar with Bruno 2000's SSL projects?
I have a little issue with my 9ks. voltages at IC22 & 29 (NE5534) on booth of my boards are not were they are supposed to be.
Pin 2 has 11,2 VDC, Pin 3 has 16 VDC
i measured these values with all socketed ICs removed from the board and signal shorted to ground at the input.
is this a normal behaviour?  :-\ it would be awesome if somebody has an idea where i can hunt the mistake.
cheers  :)
hey guys,
a little update.
according to the original thread's information the 9k should have 75db of gain.
i can not test it 100% accurately, but my pres give me only 24 to 25db of gain.  :eek:
mh something strange is going on.  ::)
any ideas?
hey thanks for helping  ;D
yes i have the schematic. it is in the attachement.
when i measure pin 4 & 7 to ground, the result is the perfect supply voltage. +/-16 VDC.
i already checked schematics, too.
pins 2 & 3 of booth ics are connected to mat02eh within the signal path.
do you think it makes sense to exchange mat02eh??
i have 2 more of them
  • SSL 9K-42Sch.pdf
