V672X (Telefunken V672a in GDIY51X format)
fragletrollet said:
What settings would be used for line levels, if suitable? Would any of the gain settings be close to unity?
You would choose
S1 =  dB Gain: 41dB / R Gegenkopplung: 12K
S5 = dB Input: -40dB / R Eingang: 24K
The trimmer R26 should be fine to adjust that one dB difference
Hi Volker,
excuse me chiming in,but I think what fragletrollet meant was writings in decibels instead of resistances?
Udo.
kante1603 said:
Hahaha...very nice indeed ,but I'll stick to german  ;D
Udo.
I second Udo. It really adds to the uniqueness of this project. I don't recall anyone having issues with German words used on vintage Telefunken gear.
Just my two cents.
Keep 'em coming, Volker!
Paul
Pardon my ignorance but another stupid question incoming... I just want to make sure I'm understanding this correctly.
for calibration there are three steps:
GAIN ADJ R26:
Generator = 1kHz -40dBu
Set R26 to measure +2dBu
HF ADJ R37:
Generator = 15kHz -40dBu
Set R37 to measure +2dBu
LF ADJ R29
Generator = 40Hz -40dBu
Set R29 to measure +2dBu
where generator is set as indicated and sent to audio in, and then you adjust the respective resistor until you measure the indicated dBu of the audio out with a VU meter? and for each of these steps the unit would be set as:
S1 = dB Gain: 62dB / R Gegenkopplung: 240K
S2 = LPF OFF / Tiefpass Überbrückt to left position (on)
S5 = dB Input: -20dB / R Eingang: 2k2
Is this all there is to it or am I way off?
