Searching Alpha 9 mm dual 100K reverse log pots.
RuudNL
Haule / The Netherlands
Hi. I am looking for a number (25 or so) Alpha 9 mm dual 100K.ohm reverse log potentiometers.
Any idea where I could get them?
The only source I could find was ebay, but the seller didn't have sufficient stock.
This is the type I am looking for:
Suggestions (preferably within Europe) are highly appreciated!
> For some reason I can't remove this posting.
If you have utterly embarrassed yourself, use the "Report to moderator" link under your post and report yourself. In "Comment", say you wish to remove your post. The gang here will normally respect posters' wish to remove their own message.
In this case, tho, it looks like you helped someone else.
