Shattersignal
I have the circuit assembled and I'm seeing strange behavior--I wonder if any of you can recognize this symptom and would steer me in the right direction to find a cause.
Plate voltage is steady on V1. Plate voltage on V2, however, climbs rapidly at power-on, hits close to it's target voltage, and then steadily drops to the vicinity of about 40vdc, where is stays. The buildup and drop happen within about 10 or 15 seconds, so I first guessed that it might be a short inside the tube, perhaps related to the warm-up time of the filament. I changed the tubes and the behavior is the same, however. When I remove the tubes and test, all voltages are steady--the problem doesn't present itself. I've played with different R values for dropping the B+ lines, as well as with different values for the bleed R. The v2 voltage issue seems unaffected by changes to the B+ voltage, except that it peaks and settles at different values, directly related to the B+ that's being delivered. It's also worth noting that the amp passes audio even with this problem--at least when the v2 B+ settles to more than 40v or so--but that there is little headroom (duh!) and poor bandwidth.
My guess is that it's either an issue with 1) the output transformer, the primary of which passes the B+ to V2, or 2) that my PS can't supply enough current and that somehow this is only affecting v2 and not v1.
My B+ PT is rated for 80va, which ought to be substantially overrated for the task. The OT is gapped for 5ma, has a DCR of 1.4k on the primary, and measures about 2.6v of drop while the amp is at idle. I'm not really sure what other info to relate which might be relevant to diagnosing the problem.
Thanks again for reading and for assisting, if you think you know where I should look for the issue!
