Yes. they're part of a voltage doubler, that produces about 23V from a 12Vac transformer. The voltage-multiplier principle is also used to produce about 60V from the same 12Vac source. https://en.wikipedia.org/wiki/Voltage_multiplierthegrupus said:Here the schematics attached,
On the power supply the C5,C6,C23 ,C16 (2200uF/16v ) are before the bridge diodes on the ac side this is normal?
They are used for protection of the input stage against over voltages, particularly those that happen when the input is shorted to ground and capacitors C46/48 are charged at 48V.And on the input mic what are de D16 D17 D19 D21 for ?
thegrupus said:nice trick the voltage doubler...
but why the protection diodes are connected to +/- 15v and not to ground?
