ruffrecords said:5751 is just an industrial strength 12AX7 with a lower mu. Typical plate current is 1mA so it is not really any good as an output stage for which you need a higher standing current.
bluebird said:Quick and easy way is to just try it with a 12AU7 or 12AT7, hook a 4:1 transformer up to it and sweep it. See if your low end is acceptable. Try and use the biggest film cap you have lying around. 10uf would probably do it.
kambo said:what effects has "higher standing current " on audio / performance, ( google is not friendly on this topic )
ruffrecords said:Standing current is just the dc current through the circuit when there is no signal, sometimes called the bais current or the quiescent current.
If you want to be able to output +22dBu (10V rms) into a 600 ohms load, you need to be able to supply 10/0.6 ma = 16.6mA rms into that resistor or nearly 24mA peak.
In a simple single ended class A amplifier with a standing current of 1mA, the output can swing up to 2mA and down to 0mA so the peak current swing is just 1mA. So the transformer would need a 16:1 ratio to drive a 600 ohm load to +22dBu. To do this the tube output voltage swing would have to be 160V rms (16 times 10V rms) which would need an HT supply of over 450V.
The circuit posted is an SRPP which is a true push pull which means its output current can swing twice as far as a single ended stage i.e 2mA peak with a 1mA standing current. An 8:1 transformer would now be needed and the output would only need to swing by 80V rms or 225V peak to peak. That is asking a lot of an SRPP stage.
The answer in both cases is to raise the standing current. If you use a different tube and raise the standing current to 6mA in an SRPP then you can output 12mA peak. A 2:1 transformer is all you need to easily be able to theoretically drive 24mA peak into a 600 ohm load and the tube output swing only needs to be 20V rms which is just over 110V peak to peak.
An alternative is to allow the maximum output to be less or the minimum load to be higher both of which would redcuce the required standing current.
pucho812 said:So like a 10uf after the output pot into a 10k:600....
rafafredd said:Plate to plate feedback???
Check the drawing. Is it really correct?
bluebird said:What do you mean? in the input or output stage? It all looks good to me...
No FB there because the 1st plate is decoupled to gnd.rafafredd said:Plate to plate feedback???
Obviously not. Second plate also needs to be decoupled. It would work somewhat, though.Check the drawing. Is it really correct?
