pahstah
Re: FFBE-32 (Famous Four Band Eq)
« Reply #40 on: September 28, 2017, 11:29:16 AM »
i'm already working on it  8)
pahstah
« Reply #41 on: October 04, 2017, 02:38:59 PM »
A newborn : Mr. Brown
« Reply #42 on: October 04, 2017, 03:29:06 PM »
So... a new name for you eq line !! The RD eq
Reservoir Dogs  8)
best
Zam
pahstah
« Reply #43 on: October 05, 2017, 05:54:16 AM »
Reservoir Dogs  8)
best
Zam
 by the way which one is Pink?
« Reply #45 on: October 05, 2017, 04:18:50 PM »
Now we are talking!! Can we have a peek at the guts?
Edit: was confusing the ffbe-32 for fbe-02. No filters after all?
« Last Edit: October 05, 2017, 04:23:10 PM by fragletrollet »
pahstah
« Reply #46 on: October 06, 2017, 05:07:46 AM »
the 02 has the same knobs pattern as the 32 but obviously doesn't have the filters because of the Q pots.
sounds really good though.
i am studying the 242 version with filters BUT i am looking for an alternate solution for dual stacked potentiometers so i can squeeze everything in a 500 series front panel (how i wish they'd have made it a 4 unit instead of 3 unit back in the days).
pahstah
« Reply #47 on: October 06, 2017, 05:19:17 AM »
guts
« Reply #48 on: October 06, 2017, 06:26:31 AM »
Beautiful!
« Reply #49 on: October 20, 2017, 09:27:39 AM »
How do I get my hands on a pair of these?!
Also is the Brown an SSL???  :D
pahstah
« Reply #50 on: October 21, 2017, 08:03:36 AM »
I'm thinking about selling these as partial or full kits. I haven't decided yet.
Mr. Brown is similar to an ssl 82e02 eq less the filters and the gainpot is also different because i couldn't find a center tapped pot with a 9mm footprint. It also doesn't have a center detent  but i've tried the eq and i've found that i don't really need these features.
« Reply #51 on: October 21, 2017, 09:57:01 AM »
If you ever do decide to sell these as full kits, count me in! Also if you ever do a mega affordable 80b EQ I'd be in heaven.
Have you thought of maybe push button HP and LP filters on the SSL? Like a good clean-up 80hz and a smooth 12k. But I know that faceplate is tight haha.
pahstah
« Reply #52 on: October 27, 2017, 05:43:20 AM »
the full kit price should be around 200-250 € for the harrison eq and 250-300 € for the ssl, depending on the front panel choice. also an 80b eq is possible.
Paolo
« Reply #53 on: October 29, 2017, 05:25:40 PM »
Paolo
Where can I order?
pahstah
« Reply #54 on: October 31, 2017, 03:52:47 AM »
As soon as ai will be ready with the new pcbs I will let you know where to order
pahstah
« Reply #55 on: November 14, 2017, 08:24:56 AM »
In this image you can see the two different versions of the s s l eq: the 02 on top and the 242 at the bottom
as you can see the pcbs have footprint for smd/through hole resistors, electrolytic and ceramic capacitors, film capacitors are wima fet are j112
pahstah
« Reply #56 on: November 14, 2017, 08:28:20 AM »
in this image you can see the front panels for 02 (brown) and 242 (black). front panel for 242 is aluminium anodized natural with digital print on it. the 02 is self adhesive paper printed with an inkjet.
peterc
« Reply #57 on: November 14, 2017, 03:58:37 PM »
Man, these are just superb!
Well done. Makes me quite envious of my own skills......
Peter
If opportunity doesn't knock, build a door.
pahstah
« Reply #58 on: November 15, 2017, 04:38:34 AM »
Peter
Thank you Peter!!
john12ax7
Re: FFBE-32-02-242 (Famous Four Band Eq)
« Reply #59 on: December 01, 2017, 04:31:59 PM »
Very nicely done.  For the pots are those Bourns 9mm? And where did you get tiny knobs?
Last post February 11, 2010, 11:46:42 AM
by Pleasurehead
Last post September 27, 2018, 06:04:47 AM
by SIXTYNINER
Last post June 05, 2019, 08:26:16 PM
by PRR
Last post March 21, 2020, 06:38:51 PM
by Cheadle96
