diggy fresh
Hi peeps!
I got this transformer a while back from a retired engineer and would like some help to figure how i could give it a second life.
I am just starting with tube circuits so i'm kinda clueless to find a suitable circuit.
The engineer did not remember the original usage. It was is some kind of "test jig box", with two octal sockets an input and multipin power connector.
(I can add pic later if interested).
Could not find any info on it on the web but it's made by Hammond.
Here's the specs on it:
Primary:
Impedance 7850 ohm
40 ma dc
8.5w max
60 cps (hertz)
Secondary:
Impedance 700 ohm
No dc
I calculted the ratio to be around 3.6:1.
I did not measure dc resistance and inductance yet because it is still in circuit. I can measure later if it helps.
So anybody has ideas how i can use this thing? The 700 ohm output sounds like it could be good for line output but i don't know enough about tubes yet to know what tube output would be happy seeing 7850 ohm:700 ohm step down.
Idealy for me would be a tube DI line output, preamp line output.
(Although i would not get balancing because of the lack of center tap.).
Any help appreciated, thanks!
John
Primary:
Impedance 7850 ohm
40 ma dc
8.5w max
60 cps (hertz)
Secondary:
Impedance 700 ohm
No dc
John
