I have "upgraded" output transformer to Carnhill with switch to go back to stock.
Huge difference? No. Better? No, rather slightly different flavour.
Carnhill has more low end, but just a tad. In the subs for the most part, 30-50hz.
However, stock Chinese is cleaner and has less distortion. Carnhill distorts sooner in the low end. Stock starts to saturate obviously when VU peaks at +8db, Carnhill at +4. Chinese has better high end response.
Coloration comes probably from harmonics, as both transformers have flat frequency response. These differences are hardly audiable, i had to perform null tests and loop 500ms of audio material on kick drums, hi hats, whole arrangements and switch back and forth to hear any difference.
I actually get almost the same effect when i send/return signal through Carnhill from my DAW and back into converters. This makes it great and cheap "warm" passive element. Sounds totaly different when primary and secondary are swapped tho. Reversed it makes +3 db bump at 40hz. But that might be interraction with Carnhill, input and output of my converters.
