Hi all,
I'm currently assembling a DR MQ5 equalizer.
The PCB is quite big.
When I gently lift it from the table, by holding the short edges with my fingers, I think I cause it to flex a little (you cannot see the bending, but it most probably bends a few tenth).
Since I've soldered all film capacitors (and some socket) on the PCB that lift movement causes a single faint "cling-ching" high-pitched noise. The noise is so low that I have difficulties in understanding from where it comes.
It sounds like it a sort of little loose metallic part, but the fact I can hear it by just gently lifting the PCB induces me thinking it is caused by the PCB bending.
In your opinion, does such noise comes from:
-the long and rigid film capacitors scraping their base against the PCB Surface when the PCB bends?
-by something inside those capacitors that is moved by the soldered legs when the PCB bends?
I'm wondering if it is something the more experts of you have ever whithenessed and if I shall consider it as not being a problem.
Thanks.
Thanks.
