Spencerleehorton
Hi All,
In have mad a few 10468 Mic Input transformers for my Neve 1290 preamps and have seen i can use the 10468 for both line and Mic if i use a relay, haven't done this yet but would appreciate any drawings of how to use the relay to this please.
My question is this, i have rigged up the input transformer with a DPDT switch so i can either have the transformer in series or parallel, the only thing is the level doesn't seem to be that different when switching between the two?
I might implement the DPDT switch with the API-312 pad configuration, just wanted to check that the series/parallel switch version i am trying works or does work that well?
whats your thoughts?
regards
Spence.
regards
Spence.
