Newmarket
I'd like your thoughts on this:
Just picked up a dbx DJdi box (Two Channel transformer Isolated Passive Direct Box).
One of those -"might be useful so put in a lowish ebay bid" purchases.
So opening it up to take a look: pretty much as expected : Input attenuator pot; Ground Lift switch (simple connected / disconnected - ie no resistor / capacitor / diode combo or anything) and two smallish transformers.
But...noticed that the secondary (ie low Z output to XLR) side of the transformers have two windings that are joined in series via the pcb.
Nothing unusual in that but the junction of the two windings is taken to the output ground / Pin 1 ie a 'centre tap'.
The two output grounds are separate but the input ground connections are common (and connected to metal enclosure chassis) so that if the Ground Lift is Off then the Pin 1s are connected together and to the Input Ground.
I don't really understand what benefit the 'centre tap' on the output windings would give over a floating output. The following input stage should perform any referencing to '0V' whether it is balanced / unbalanced ?
I'm used to active balanced configurations etc but not quite so much transformer stuff so wondering if I am missing anything with this design ?
