CJ
Anyone built a 'What Compressor'?
« Reply #60 on: May 16, 2005, 10:04:14 PM »
Doh!
 :thumb:
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
tony dB
« Reply #61 on: May 17, 2005, 05:04:13 AM »
Fabio, you DA MAN!!!  :thumb:
 :guinness:  :guinness:  :guinness:
chrissugar
« Reply #62 on: May 17, 2005, 05:35:03 AM »
Quote from: "Bauman"
Hey!
Do you guys still wanna some PDF layout to home etching?!
 :guinness:
Fabio
Gerbers would make me happy if it is not too much to ask. :grin:
chrissugar
Christian Mike Sugar
        CMS-LAB
smallbutfine
« Reply #63 on: May 17, 2005, 12:48:49 PM »
YES! :grin:
thanks again for the pm you sent me...
nevertheless i probably wanna build more of this (more channels...)trying to home etch in farer future...(after testing)
So if you would share, it will be a great donation to this forum.
Not only for home etching but also to show how you did all those options...
 :grin:  :thumb:
kind regards
Martin
(btw finished my first doublesided home etched pcb yesterday, was a weak joe...looks ugly :wink: but should work ok after stuffing now)
"In the past we suffered from crimes, today we suffer from laws."
Tacitus
www.audiomh.de
Flatpicker
« Reply #64 on: May 17, 2005, 03:37:35 PM »
Fabio rules!  :thumb:
Keep us posted on sonic differences between transformerless 5532 versions vs. the OEPs w/Melcors.
AnalogPackrat
« Reply #65 on: May 17, 2005, 05:48:32 PM »
Question for all you WHAT builders using Fabio's boards:  What transformers do you plan to use?  I'm thinking the LL1540 for input and some kind of Cinemag for output.  Anyone have an opinion on bifilar vs. quadfilar for output?  I was looking at the CMOB-2H (or 2L) or maybe the CMOQ-2L.  I'm planning on making a linkable pair and wiring for the optional attack, release, and ratio controls.  Thanks for the help.
:guinness:
Analog Packrat
If it is to be, it is up to me.
[email protected]
« Reply #66 on: May 17, 2005, 06:05:04 PM »
Single ended line in and CMOB-2L out for a rich bottom. Gonna drive it with a discrete opamp.
AnalogPackrat
« Reply #67 on: May 17, 2005, 07:13:53 PM »
Tamas,
   Well, I feel better about my output trafo selection now  :wink: .  What  discrete op amp are you going to use?  Would your GainBloak be usable in this circuit?
Analog Packrat
Miska
« Reply #68 on: May 19, 2005, 03:46:23 PM »
Yes please, if that's possible.
Thanks, Miska
[email protected]
« Reply #69 on: May 19, 2005, 04:09:09 PM »
Quote from: "AnalogPackrat"
I will try a few different ones. I will test the GainBloak also and see if the DC offset is tolerable on the output.
AnalogPackrat
« Reply #70 on: May 19, 2005, 11:10:55 PM »
Great.  Thanks, Tamas.
Analog Packrat
Gulistan
« Reply #71 on: July 02, 2007, 09:23:26 AM »
if someone could send me the pdf, I planning to build a WeakJoe and this version...
Re: Anyone built a 'What Compressor'?
« Reply #72 on: October 07, 2010, 06:35:54 PM »
I know it's been a long time since there was any activity on this thread but do you need a line driver/receiver circuit for the input/output/sidechain?
has any body used any transformers on the in / output if so will a 1:1 ratio transformer do?
How would I wire the transformer?
Cheers for any reply
D
« Reply #73 on: December 23, 2020, 06:00:25 AM »
Hi Guys.
Does anyone still have the BOM of What Compressor on Peter C old webite? https://web.archive.org/web/20040604232134/http://1176neve.tripod.com/1176/id5.html
Thank you for any replies :)
Ipin
peterc
« Reply #74 on: December 23, 2020, 07:02:53 AM »
Here it is
Not sure if the part numbers correspond to the PCB overlay.... Might have to confirm against the schematic. I have changed PCB software since doing this and dont have the old package any longer.
If opportunity doesn't knock, build a door.
« Reply #75 on: December 23, 2020, 08:36:11 AM »
Here it is
Thank you Peter! Really appreciate that, will check the layout and the schematic :)
Ricardus
« Reply #76 on: December 23, 2020, 11:32:25 PM »
Now I'm curious...
Audio mastering for hire..
Last post December 07, 2005, 07:38:49 PM
by neilwight
Last post September 28, 2018, 05:46:37 PM
by psych60s
Last post June 16, 2009, 12:23:26 PM
by punk
Last post January 07, 2010, 10:59:29 AM
by gary o
