Whoops said:Why would buy old Tant caps that can fail at any moment when you could buy modern caps that are much more reliable?
ruairioflaherty said:If you are repairing a vintage piece cap substitutions can have an effect on value, and if you are a detail guy/gal then you may want to use original components in a recreation too.
ruairioflaherty said:Why would use that old Neumann mic when we have these brand new ones?
thekid777 said:Stereo field was much smaller, depth as well, voices became sibilant the overall sound being
much less warm and detailed.
thekid777 said:So, yes, I would like to find some of these old caps to keep at least the great sound and balance they put in this circuit!
iampoor1 said:I dont think this is a good analogy. The neumann mic doesnt have self destructive tendencies after a certain age....
Whoops said:That's not possible, something was wrong with your test.
You will not find it, there's no NOS (New Old Stock) in tantalum caps just DOS (Deteriorated Old Stock)
Remember you're looking for DOS caps
Whoops said:Definitely, it was not a good analogy, but I think Ruairi thought my advice was to replace tantalum with electrolytic so he probably was referring to that.
ruairioflaherty said:the caps in certain 50's tweed Fenders or a U47 for example.
thekid777 said:Well, nothing was wrong, I replaced these tants with the same value and voltage as the originals
and I didnt buy cheap tantal ones... (costed me 200€ as I wanted to recap all the output line amps)
The tants which are in my console are 40 years old and works really well, not really DOS.
I know many persons are running the same console without replacing these.
None are shorted and yes, sounds much better to my ears than the new ones.
