Pigbenis27
Member
- Joined
- Sep 26, 2017
- Messages
- 16
Hi There everybody!
I'm currently in the process of fixing a broken down SSL Power Supply Unit. I have replaced several parts that were blown and now that i am hoping to actually clean the darn thing out before starting it back up again. My first question was what is the safest way to clean general gunk and corrosion out of electrical components without shorting anything out or damaging any parts? I have tried air duster and unfortunately it isn't enough to get rid of a lot of the build up.
My second question is in regards to the pictures below. Out of all of the connections and connectors inside of the large unit i have been fortunate enough to have only found three connectors that look to be corroded/fried and i was hoping to inquire what the best way to fix these would be? should I just cut the corroded/fried section of wire and install a new connector? or should i install a new wire altogether? unfortunately the two burnt connectors in the picture below are actually coming straight out of the transformer and were connected to a Bridge Rectifier that clearly fried itself. The Transformer itself looks to be fine and it is still sending power to other components in the PSU but still i need to ask should i be looking into purchasing another transformer as well?
Thank you guys for your time and help in the matter!! I greatly appreciate any advice you can give me!
Tony
Tony
