WTB Neumann K870/K67 capsule
I have a K87 if you like. I believe the similarities between the K870 and K87 are so tiny they are interchangeable, and as I understand it, Neumann themselves claim there is no difference between the two capsules. The K87 was from original u87's and I believe the K870/67 is used in newer u87's.
I can send a couple of pictures if you are interested.
Thanks deuce42
But i thinck that 's not the reel same capsule
you can see with this link
http://www.vintagewindings.com/gen%20pop/8299543VW8335/ProAudio1/Neumann%20Microphone%20Capsules.pdf
ilikeit said:
Thanks deuce42
Electrically they are the same. The only difference beeing the thin insulation layer between the two backplates in the k87. But if you bridge the two backplates you practically have a k870/k67.
Exactly, they are the same, with the difference being the insulation of the backplates. Neumann and Klaus Heyne confirm that as well.
Hello,
I have some used  available on my reverb shop, also  a couple  reskinned  (never used) by Thiersch, not in Reverb listing:
Neumann K67 / K870 Capsule for Neumann U87 Ai
https://reverb.com/item/4878352-neumann-k67-k870-capsule-for-neumann-u87-ai
