Hey folks,
I'm planing a Siemens SM204 build and spoke to a really knowledgeable person who advised me to not build it in the original configuration (6072 in single triode with the other side grounded) but to build it with both triodes in parallel. In conjunction with a lower ratio transformer (7:1 instead of 9:1) this should decrease noise a bit (I read only by about 3dB) and it should also be better for the tube as the unused side can somehow deteriorate after some time.
Also he said, that the Siemens in original configuration goes kinda deep in the lows and "rumbles" as a result. This is not the case with the tube in parallel.
But I believe the folks at AKG had a good reason to run two of their top mics in single triode mode(C12, Ela M 251).
Or maybe not?
So I just wanted to ask for some opinions around here who have experimented with parallel triodes and also maybe a hint on why AKG did it the way they did it.
Or maybe not?
