Wired up Patch panels x 3
£39 each + postage
See pics
Patchbay High Quality - patch panels. Custom point to point Van Damme wire used.
To use this is must be installed into a rack or case.
You have a front and a back panel, with high quality point to point soldered Van Damme cable linking to patch panel on other side. Balanced throughout. (Think from memory it's also wired to accept unbalanced cables.
Suitable for any rack or flight case that is max 43 cm deep - panels must be screwed in at BOTH ENDS (so you have a front and a back panel to patch into), so not suitable for a rack or case that only has screw holes on one side.
I had 4 of these built into a flight case. I've now selling 3 as I just don't have as many synths as I used to.
£39 each + postage
See pics
