Stagefright13
A cheap meter is a cheap meter. Always have one hooked to the power supply caps while working on your circuit. Use clip on leads and have it on all the time. And safety will be obvious by reading it. And NEVER put more than 1 hand in the "Box". Always keep 1 hand in your pocket.
Use your "Good Meter" for measurements. I think radio shack has cheap meters for like 15 bucks. Or even Sears etc.
Your links need a password btw...
If you power transformer smoked then it is not hooked up properly. Or you have a short after it.
