JCN1218
Hey everyone. Been looking around for an answer to this one, but I haven't had any luck. Here's the situation:
I'm building a stereo 1176 using Mnats' boards and the separate power supply. I have everything in the boards currently, and my fuses finally came in the mail, so I figured I'd test the PSU to make sure it was working properly.
I plugged in the main power and flipped the switch. First thing I noticed was that only the red test LED on the PSU board was lighting up. Also, upon checking with my meter, it seems like the power supply is outputting only AC current instead of DC current. Nothing has started smoking or bulging or anything like that, and I've checked everything on the board as well as my transformer wiring at least 10 times. I'm almost certain everything is as it should be, I just can't figure out what's going wrong.
Any help would be greatly appreciated. Especially since once this problem is sorted out I can pretty much finish the unit (provided that nothing else goes wrong in the process).
