80hinhiding
- Joined
- Sep 27, 2016
- Messages
- 97
In order to answer your question, we would need to know where this cap is in the circuit, and what the circuit is.80hinhiding said:Why do capacitors have different resonant responses?
One example, I just changed a 0.1uF MKT1822 film cap with a 0.1uF K40Y-9 paper in oil and the difference isn't slight, it's quite noticeable. One of the two emphasized an acoustic guitar in a mix that could be barely heard through the other. Notes played on an electric organ through one capacitor resonant while the other just fall off quicker. Not arguing for or against either, I just want to know why this happens.
Adam
I don't see how the cap's technology could make a significant difference in this application, unless there is a large effect due to stray capacitance. I can't comment without having some objective data, such as a frequency response. BTW what was the source?80hinhiding said:It was on the input of the bare bones differential amp PRR drew up in the thread about an ideal line input stage. That diff amp output then went to a voltage follower I made with a JFET, which then feeds an output amp that is Class B in design. Output transformer was used, sent unbalanced to a speaker.
One capacitor is rated for 250V, the other rated for 200V. I believe they're both +-10%. Both 0.1uF.
Adam
In the actual configuration (in series with a 100k resistor) I very much doubt the effects of dielectric absorption or dissipation are detectable compared to the distortion level in a single transistor with current NFB, unless one of the caps is seriously defective.Audio1Man said:The dielectric material, temperature coefficient, dissipation factor, construction and other factors cause changes as current flows and voltage across the capacitor cause non linearity to show up.
