I guess it was what it was intended for; it is labelled as a "program amplifier", but its gain is excessive in that position. It could be a mic preamp, not particularly good at that.Michael Tibes said:Would this work as a (relatively) low impedance mix bus input?
Michael
CJ said:try it and see, if you get a different sound out of it then you have a tool for creativity,
ruffrecords said:Unfortunately, the noise at the input of this circuit is the same as at the grid of a common cathode circuit, and the gain is also the same,
With the 2.7k +500r cathode res, it makes a little more sense, but it's just a curio, with no real advantage.bluebird said:Seen this one floating around, might even been talked about here before but its peaked my interest. Looks like you would definitely want some input caps. A better output stage that could drive a little more with a bit more gain would be nice. Always liked the idea of using a low plate resistance 6AS7/6080 for an output tube, only capable of 6db gain but can drive 600 from the plate no problem. Then what always stops me is the heater current (2.5A)
http://wooaudio.com/docs/tube_data/6AS7GA(6080).pdf
