madreza
few question about the G9
« on: April 06, 2005, 04:13:15 PM »
on the part list I have 4  47u 50V  RAD.EL.LYT     TRIPLER P48
but on the pcb it's written 47u 63V
which one is right ?
( I bought 50V , would it work ? )
same problem with C3/C103 which are 470nF on the part list and 220nF
on the PCB !!!!
except that my first day of soldering was cool !  :grin:
Knight 1: We are now no longer the Knights who say Ni.
Knight 2: NI.
Other Knights: Shh...
Knight 1: We are now the Knights who say... "Ekki-Ekki-Ekki-Ekki-PTANG. Zoom-Boing. Z'nourrwringmm.
gyraf
« Reply #1 on: April 07, 2005, 04:03:42 AM »
both will work fine..
madreza
cool
« Reply #2 on: April 07, 2005, 05:22:31 AM »
thanks jakob !
you rule !  :grin:
Knight 2: NI.
madreza
« Reply #3 on: April 08, 2005, 06:49:42 AM »
sorry guys I have a new question !
about the relay,
No way to find some 12V 2xCO
someone told me to take 2xRT and he didn't know what 2xCO was !
anyone knows where to find 2xCO in europe ?
( I'm nearly done with it !  :grin: )
Knight 2: NI.
« Reply #4 on: April 08, 2005, 07:01:53 AM »
I see what you mean
The parts list says
12V 2xCO RELAY
What that means is
2 lots of a "change over" relay
e.g. DPCO or DPDT (x2)
madreza
« Reply #5 on: April 08, 2005, 07:03:00 AM »
oops sorry !
I just found a topic about the relay !
 :oops:
Knight 2: NI.
Ethan
« Reply #6 on: April 08, 2005, 10:27:30 AM »
Please read the forum descriptions before posting so that your post gets the proper attention.  I'm moving this to the lab.
I am just the Web Geek here.
madreza
« Reply #7 on: April 08, 2005, 07:54:27 PM »
Yep ! Sorry Ethan !
When I first posted it I thought it was in the lab
Once posted ( and it took me a few time to realise )
I saw it was in the black market !
Sorry Guys !
Knight 2: NI.
Hulk
« Reply #8 on: April 17, 2005, 03:58:49 PM »
Quote from: "uk03878"
I see what you mean
The parts list says
12V 2xCO RELAY
What that means is
I'm building the G9 too - but I still don't get it :roll:  - what is a DPCO or DPDT??
Hulk
gyraf
« Reply #9 on: April 18, 2005, 04:24:19 AM »
Double-Pole-Change-Over
Double-Pole-Double-Throw
Hulk
« Reply #10 on: April 19, 2005, 07:34:09 AM »
Tak, Thanks, Danke, Merde :shock:
Can I use 0.6W resistors on the G9??
Can I use a 50K log pot for the "output level" ???
Hulk
Hulk
« Reply #11 on: April 19, 2005, 07:45:38 AM »
Ok I can use the 50k pot - didn't see the "potentionmeter question" post :roll:
Hulk
mcs
« Reply #12 on: April 19, 2005, 08:16:02 AM »
Quote from: "Hulk"
Just use an Omron G5V-2 - very easy to get (from Farnell, RS, Elfa etc.).
Best regards,
Mikkel C. Simonsen
Hulk
« Reply #13 on: April 19, 2005, 08:26:58 AM »
I have found some DPDT's I'm going to use!
I have searched - Can I use 1% metal film 0.6W resistors in the G9????????????????????????????????????????????????
 :guinness:  :guinness:
Hulk
gyraf
« Reply #14 on: April 19, 2005, 08:43:30 AM »
Yes. 0.6W is standard around here now.
Hulk
« Reply #15 on: June 30, 2005, 06:58:38 AM »
I just finished my G9 a few days ago and when I tested it with my RME converter I got a Bzzz sound at -40-50 dB on both channels - the strange thing is that if I turned the power of the G9 and recorded I still got the Bzz sound so something is "bleeding" even though the pre amp is turned off!!
   I'm going to work on it today so I just want to hear of any of you has some advice where to look for the problem??
   I have grounded the 230V power input to the chassis and I have grounded the input XLR's at the grounding pin on top of the Neutrik XLR's and then I have connected all 4 XLR at pin 1.
   I can measure around 9,5VAC on every pin on the XLR's or on the top of the OEP/Lundahl trafo's
Any advise where to look before I start to take everything apart??
Hulk
Hulk
« Reply #16 on: June 30, 2005, 07:01:10 AM »
... and if I only measure with the negativ (black wire) pin from my multimeter I get around 2.5VAC???
Hulk
gyraf
« Reply #17 on: June 30, 2005, 07:02:47 AM »
are you using grounded mains power? that is, 3-pin mains plugs into wall socket with ground?
also try connecting the two chassis's with a piece of wire to rule out potential differences.
These problems probably comes from the power inlet filter in the rme - you NEED to run it on grounded mains..
Jakob E.
Hulk
« Reply #18 on: June 30, 2005, 07:09:32 AM »
No I'm not using gronded mains!
...but I tried to connect the the gronding pin on the power input to a radiator  and that only enhanced the Bzzz sound??
Hulk
gyraf
« Reply #19 on: June 30, 2005, 07:25:44 AM »
As I said, I think it's the RME, not the G9..
Last post August 19, 2005, 01:16:49 AM
by netcastle
Last post January 07, 2007, 09:51:27 AM
by Samuel Groner
Last post August 12, 2009, 04:35:08 PM
by syn
Last post April 23, 2012, 07:48:34 PM
by Lowfreq
