CJ said:does this amp have short protection? speaks got cooked,
That'll do it.... I recall one unfortunate incident where a certain Peavey speaker crossover would make a certain Peavey topbox oscillate. The speaker then not only released its magic smoke, but flames .... That problem was found and corrected pretty damn quickly (by the speaker guys, who screwed up the crossover design ). Peavey amps are designed to be stable driving almost any load, but stuff happens.CJ said:thanks for the help! yes, that is a thermal breaker (see pic)
turns out the lead channel oscillates at 16 K Hz when the vol is 50% or more, which is what cooked the speaks, so we are going to track down the source and squelch it.
Yes Jack (RIP) was the man for preventing secondary breakdown using VI limiting (kind of like foldback current limiting).PRR said:> current limiting.
I believe it is VA limiting. It allows more I if the transistor V is low. This puts full power in rated loads and doesn't try as hard when the amp is shorted. This was fairly well understood from early days; PV's Jack probably knew it better than most. This one is a bit too complicated for me to work out in my head.
OK if that is transtube there is more to think about... some transtube models used positive feedback to manipulate the amplifier output impedance (to be more tube like) and promote speaker/cabinet impedance interactions. If that non-typical NF is wonky oscillation could be a result.CJ said:Hi Gus! This amp is a Peavey Special 212 Transtube Series.
going to see if we can tame that Lead circuit in case someone uses a gnd lift adapter thus saving a Shefield cookoff contest.
https://www.electronica-pt.com/esquema/audio/amplificadores-audio/peavey/peavey-transtube-special-212-orig-1995-schematic-28100/
Not a service tech but Grant Brown ran the entire service department probably that long... If he isn't retired now he is due..CJ said:Thanks JR! Hey you know a tech named grant from PV? said he has been there 40 years,
there is also a "Dynamics" knob at the bottom of the schemo that affects the power output, when it is set to about 50%, power is reduced but the waveform gets real funky,
my primary house band was Robodrum https://soundcloud.com/robodrum/10-robodrum-beer?in=robodrum/sets/robodrum keep listening more than one song, but the homebrew Bob mentions in Beer song is Johnny Beer. If you stay with the songs ... I watched them get their power cut off and kicked out of the bar when they played the country version of "Highway to hell", no sense of humor even in MS. ;D (I can't vouch for the sound quality of that cloud poop..we tracked on AMR 4T cassette and mixed down to 2T didn't totally suck, but you know how memory works.)CJ said:holy cow who played at your house parties?
Yes, Grant is a good old boy and I've seen him with and without beard. I can't say what he does on weekends (i don't want to know).yeah Grant was very nice on the phone, talks kind of slow like mid-western types, sounds like he wears a beard and goes "noodling" for blue cats on the weekends,
here is the preamp, the Ultra and Lead channels look almost identical, so now we have a way to compare signals side by side and see what differs. lots of discrete Darlingtons, eh?
That is Bob Hopkins on lead guitar, Jim Albert on bass, Brian Hughley drums. Now the three are spread around the country.CJ said:holy cow those guys are smokin hot! sounds like a strat/humbucker thru a classic 30 with a tube screamer in front,
who is that guitar player?
I like 3 wire line cords on guitar amps... good job.took out the 'death caps" when this amp came in, turns out a .01 from neutral to chassis kills the microwave oven noise,
presence control would control the amplitude of the osc.
upped the voltage to 500 with a ceramic, time to call it good and move on, Mr. Brown told me not to change any parts but it was too late, luckily we have a PV bandit sitting out i n the garage that has offered to donate a 12 inch and there is stuff hanging from the ceiling so hopefully we will never see this amp again.
HF osc and the cap that fixed it along with the 3 lead cord being reinstated.
