Neve 1290 preamp - output pad , 4 step attenuator
Vac11
Czech Republic
Hello everyone,
I have one question. How can I do a stepped output pad (attenuator) for the Neve 1290 preamp?
I know it can be done by putting a 5K (or 10K) linear conductive plastic potentiometer behind the second section i.e. BA283NV and before the output section i.e. BA283AM.
I have some 4 position (3 deck) switches that I want to use for that. I would like to have these values of attenuation:
0 switchs position (fullclockwise) …………….….. 0db
1st switchs position……………………………….........-6dB
2nd switchs position ………………………………......-12db
3rd switchs position (counterclocwise)……....-20db
Would be there funktional a basic 600 ohm L pad for attenuating unbalanced signal?
Is good idea to use rotary switch instead of a conductive plastic pot?
Any help would be much apriciated!
Best
Milan
You can get reasonably close to these values by using a 4K7 resistor between the first and second positions, a 2K4 between the second and third positions, a 1k$ between the thrid and fourt positions ans a 1K from the fourth position to 0V.
I'm doing a 1073 right now and I added a relay to switch the secondary of the OT from series to parallel but in doing so it also switches in a 150 ohm load. The idea is to be able to overdrive things and provoke the character of the gapped OT but without blasting downstream gear that can't handle it.
I haven't tried it yet though.
Thank you Ian
You think like this?
Update 1: Changed resistor order
Update 2: Changed 1K to 1K3
Update 3: Changed 1K to 910R and 1K3 to 1K4
Vac11 said:
Thank you very much Ian. I updated scheme, so other members can use it...
M.
That is exactly as I designed it in my head. Looking at it now the -20dB is a bit inaccurate. If you change the 1K to 910 ohms and the 1K3 to 1K4 it should be more accurate.
That's what I thought you said the first time.
Clearly fumble-fingered. "$" is shift-4 on my keyboard. Probably yours also.
I did but I forgot to make the bottom R=900 ohms. The I realsised the 6dB position was wrong because the lower arm was 4K8 so for some reason I took the extra 100 ohms off the 1K4 instead of off the 1K. The  I realised the 20dB position was wrong and took 100 off the 1K and added it back to the 1K3 to make it 1K4.
Just shows that perhaps at my age I should not still be trying to do these in my head.
