dirty1_1garry
HI folks!
Want to build a guitar pedal type compressor/fx box so it can get both balanced line level signal and unbalanced guitar level signal on same TRS jack.
One more aspect is 9Vdc wall adapter power supply typical for guitar pedals.
For supply ICs I’m planning to use Traco DC converter which create +15Vdc and -15Vdc from 9Vdc with separated ground.
For bal line in/out - That 1246/1646 drivers
For unbal in/out - simple opamp buffers
For switching between balanced and unbalanced inputs/outputs planning to use group of relays.
schematic sketch attached.
question is:
how it’s better to organise Sleeve pin connection in an aspect of that balanced line Sleeve pin is typically connected with a chassis, but in unbal connection its typically connected with signal ground (especially that signal ground is separated by DC conversed from 9Vdc supply ground)
question is:
