joakimkarlthomas
I needed a 50k linear pot today, but didn't have any at home. So I thought I would try to decrease a 470k pot with a resistor. I used a 56k resistor between the outer pins of the pot. When I measure the outer pins I get 50k as expected. But when I measure outer pin to inner pin while switching the pot, then the resistance starts at 0, then goes up to over 100k in the middle and then down to 50k when all the way up (or reverse between inner an the other outer). This can't be right?
