Neumann u87 vintage circuit frequency response
kingkorg
Norway
Hi mates.
I just got an u87 with ruined capsule to try to fix. The first thing i did was to measure frequency response of the circuit to compare it to my clones, and some other mods, and i kind of got shocked. I used several different inject points suggested by people, and the result was the same. -3 to -4 db attenuation at 20KHz.
Nowhere near -10db at 20KHz suggested by a lot of people. However these -10db work great on my mics with 797 capsules, and few other. They match well with u87 takes. I am also puzzled as i have read that original Neumann capsule is actually even brighter than chinese replicas.
The mic i have is an old, black u87 with isolated backplates. That one should have even stronger HF de emphasis than newer ones.
I would have solved this puzzle immediately by putting original capsule into a flat mic, but it's unfortunately ruined.
This is the original Neumann U87 specification:
Voltage gain (1 KHz, 1 Kohm termination) -4 dB
Rel. gain 40 Hz.  -3 dB  (+/- 1 dB)
at 16 KHz.  -4 dB
Measured through the 'messeingang'.
I think -10 dB at 20 KHz is a bit too much...
Sounds about right.
http://audioimprov.com/AudioImprov/Mics/Entries/2014/2/7_Mic_Electronic_Eq_Pt.1.html
