rdahlqvist26
New member
- Joined
- Nov 15, 2017
- Messages
- 3
Hey, I was calibrating my FET 1176 Rev D today and stumbled across a problem. When I was doing the Q-bias step nothing happened. The potentiometer did not engage the meter at all, I even measured the voltage to see if something was going through but it was not. I sat down for hours following cables and looking for problems but I could not find anything. The potentiometer is working, I measured the resistance between the legs and it changed when I turned it. I checked the tutorial on your site that describes how you should put the cables to their positions and numbers and everything was done the right way. I can not find anything about this particular problem on the internet. Do you guys have an idea what can be wrong? Best Regards Rasmus
