s2udio
Re: Any Cubase users here?
« Reply #20 on: January 24, 2018, 07:26:17 AM »
If you have a legit 9.5 cubase licence it will also work for all other dongle based versions.
All versions will install seperately  on the same PC ;)
On the end of a Rural Twisted Pair.
Mbira
« Reply #21 on: January 24, 2018, 09:40:26 PM »
If you are replying to my comment-I'm on a mac and the old versions with the 32 bit plugins are not able to be installed on the "new" OS's.  My laptop is still running 10.10 and it is too new to install the old versions.  I'm not sure if that is different on PC or not.
Joel Laviolette
Rattletree   |  https://www.rattletree.com
The Rattletree School of Marimba | https://www.learnmarimba.com
Mbira
« Reply #22 on: January 25, 2018, 12:30:31 AM »
Just to clarify as well...if you have for example Cubase PRO on the dongle, that does not give you the ability to run Cubase Elements or another version of cubase-only older versions of cubase pro.  You still need to buy elements separately.  A lot of people don't like that, but it is what it is....
Well-let me clarify again...lol...I know you can not run Cubase Elements WITHOUT a dongle even if you have Cubase Pro.  I wanted to easily be able to do basic editing without having to pull out the dongle, so I bought elements to install separately on the laptop.  Maybe you can run Elements for free with a dongle if you also have pro on the same dongle?  I don't really understand what the point of that would be though.
Joel Laviolette
john12ax7
« Reply #23 on: January 25, 2018, 01:38:33 AM »
I downloaded 9.5 to demo.  Why is cubase routing so complicated? Any other daw you can easily see (and set)  the i/o, on the mixer you see where the signal comes from and where it goes.  In cubase you have to scroll through menus for this. Am I missing something?
And solo buttons are red.  Really?
Mbira
« Reply #24 on: January 25, 2018, 07:29:03 AM »
Yeah you are just missing it.  Go to the mixer screen (F3).  Click the "Routing" button above each track and they drop down.  If for some reason you have the routing button hidden then click the "racks" thing at the top and make sure routing is checked off.
Joel Laviolette
john12ax7
« Reply #25 on: June 01, 2019, 07:18:39 AM »
Cuba's 10 is 50% off for another few days,  the crossgrade even cheaper.  I've never really gotten along with it,
but  considering getting it just to have for future use, as it will probably never be cheaper.
