Drawmer 1973 Multi-Band Compressor?
Hi
I've one Drawmer 1973 and it's a great deal for the price!!!
I'm using it for mix and mastering duties and it do good joobs.
The only thing is the mix pot  is not perfectly matched between LR on all position but it's not a big problem.In future when the unit will be out of warranty, I will change it with a stepped pot.
A stepped pot will most likely have the same tracking problem as a non-stepped pot since it simply is a pot. You´d need to use a switch for that purpose. Or buy a load of those pots and find the one with the best tracking.
