bruno2000 said:I have a DCA Pro that I like very much.
YMMV
Bruno2000
thekid777 said:Hi Bruno! Thanks for the advise!!
Looks like a great tool, not expensive and portable, I looked at the manual and all is nicely explained.
I think this is the one!
Would you know if I should match them with Hfe, Vbe or use curve tracing according to their function in the schematic attached?
bruno2000 said:I match hfe, but there are much smarter folks than I am here that can probably answer more expertly.
Bruno2000
Thanks for the heads-up Whoops. I checked out your link; this unit seems to be very much a more basic tester than the DCA Pro 75; are you saying you feel this is better, and why?Whoops said:Hi everyone,
I have a Peak Atlas DCA Pro 75 and although I love the unit, for basic transistor testing and matching I would recommend the following unit, it works very well and to be honest if I had it 2 years ago I would never had bought the DCA 75:
http://www.ebay.co.uk/itm/Portable-MK328-LCR-ESR-Tester-transistor-inductance-capacitance-resistance-meter/171927184554?epid=870231183&hash=item2807a8a4aa:g:MdoAAOSwk0pVgETb
Just would like to point that although HFE should be matched with curve tracing (that the DCA 75 does) within the circuit range, when you read in this forum and other forums people matching transistors 95% of the time they just measure HFE with the conditions their tester permits.
Thanks ungifted.ungifted said:Same question, Chinese transistor testers doesn't measure jfets Vgs(off), have no curve tracing features. Basically M328 can be compared with DCA55 and have more features. But DCA75 is more pro tool imo, if we speak about transistors and diodes.
Phrazemaster said:Thanks for the heads-up Whoops. I checked out your link; this unit seems to be very much a more basic tester than the DCA Pro 75; are you saying you feel this is better, and why?
I don't see this unit doing any curve tracing...wouldn't it be better to get the Atlas Pro?
The DCA75 costs 111 pounds
Whoops said:Answering ungifted, yes the MK328 doesn't do Curve tracing, But measures JFets.
For 17 quid you can't go wrong with this unit.
PRR said:>> DCA75 costs 111 pounds
> It doesn't here
£83.30 looks like $111(110.96) in my money. I suspect Whoops was just looking on the wrong side of the currency changer.
