thekid777
Which nice affordable ultrasonic bath?
« on: November 27, 2017, 03:55:40 PM »
Could you please recommend me one?
Looking to clean old multipin connectors, face plates, some pcb...
PRR
Re: Which nice affordable ultrasonic bath?
« Reply #1 on: November 27, 2017, 04:42:23 PM »
You better narrow that down. They run from $24 to $1200, mostly depending on size. $24 goes to 3 inches: jewelry, not eyeglasses. 9-pin, not 179-pin inline. $1245 gets 5 GALLONs (22l), 19 inches (0.5m), enough for a small dog (but they shouldn't go in the ultrasound) or maybe a 19" rack panel.
So how big are your dirty bits?
thekid777
« Reply #2 on: November 27, 2017, 04:44:13 PM »
Hi PRR :) no dog here!
Mostly 20 cm X 10 cm
« Last Edit: December 16, 2017, 09:56:19 PM by thekid777 »
thekid777
« Reply #3 on: December 16, 2017, 09:55:53 PM »
I don't know where to look, there's a ton! don't know which power would be suitable and which liquid should be used to not hurt plastic parts and pcb-components?
Thanks! ;)
RuudNL
« Reply #4 on: December 17, 2017, 04:51:59 AM »
I hear a lot of good things about the Crest ultrasonic cleaners:
www.crest-ultrasonics.com
There is a solution for every problem!
http://www.vansteenisaudio.nl
madswitcher
« Reply #5 on: December 17, 2017, 03:10:10 PM »
Hi folks,
intuitively, electronics and ultrasonic cleaners don't seem to match up to me. - water ingress, micovibrations etc.  What do people use them for; are they any use in cleaning up the solder side of pcbs for example -if so what is the liquid in the bath?
Having said that I do have a small ultrasonic bath, but never thought of using it on electronic stuff.
Regards
Mike
RuudNL
« Reply #6 on: December 17, 2017, 03:29:29 PM »
I wouldn't worry too much about mechanical vibrations; I know that ultrasonic cleaners are often usen to clean computer motherboards with lots of SMD components, appearantly without any problems!
« Reply #7 on: December 17, 2017, 06:16:13 PM »
My uncle who owns a clock and watchmaking repair shop has a vintage Tube ultrasonic cleaner ,2x EL34 quite a small C core transformer , Im not sure what solvent he uses ,but most likely its petroleum based so not really something you want to be dipping electronics into , Id say examples of this kind of unit could be found cheap nowadays .
fazer
« Reply #8 on: December 19, 2017, 09:16:13 AM »
I have a small jewelry one .  Used it to clean the jewel bearing on my ampex 1200 and 102 .  It has set for years. I’ll be getting it out again.  I just got the 1200 back. And will be going through it.   Not sure how much I’ll be using it but  will transfer some old 2 inch one more time if all goes well.
