80hinhiding
- Joined
- Sep 27, 2016
- Messages
- 97
80hinhiding said:PS. The LM394H and replacements are more costly than I realized.. maybe I won't test drive this amp.
metalb00b00 said:http://www.ericasynths.lv/en/shop/diy/diy-accessories/npn-matched-transistors-in-dip8-case/
80hinhiding said:Looking at the schematic again,
80hinhiding said:This is the schematic I was referencing from another thread.
I might setup two different mix amps, and switch between them depending on material.. using dual gang controls on them to affect both mix amps. Sort of A/B compare the mixdown. One IC based, one discrete component based.
Adam
80hinhiding said:I might setup two different mix amps, and switch between them depending on material.. using dual gang controls on them to affect both mix amps. Sort of A/B compare the mixdown. One IC based, one discrete component based.
