Hi there, i tried to build this simple dub siren from www.jacoblysgaard.com , i used this schematic: https://www.jacoblysgaard.com/2009/08/dyi-dub-siren-%E2%80%93-the-complete-rubdown/#jp-carousel-2583
and i only changed the polarity of 220uF and used a diode 4001, something like this: https://drive.google.com/file/d/0B196Ckm5zNKhbjhxTW83ckt5X2c/view (updated)
But i get no output signal at all, the only thing i can hear is this "tapping/clicking" sound when i turn the pots. The pots work and function, i can hear the operations of each pot but the "sound" is a click/pop, no wave signal. I have checked the connections 5 times and all is OK. I also measured with multimeter the voltages at IC555's and the problem was at IC1. PIN8 (+VC) is 8,20V., but PIN3(OUT) was 0,01V. I replaced the IC1 with a new one but again i get 0,01-6,20V at output PIN3. It varies in this range, it isnt stable. I have changed the IC1 3 times but the same results. Maybe now it works cause i have smthing at least (even if its not stable-the first time was exactly 0,01)
I have read the comments in link's page but didnt found a solution. Has this schematic other problems/errors except for the 220uF capacitor polarity?
People say at the comments that the second schem https://drive.google.com/file/d/0B196Ckm5zNKhbjhxTW83ckt5X2c/view works well. Is there any difference comparing with the first schem except for that 220uF polarity (and the optional diode) that i don't see there?
Any help would be appreciated.
Thanks in advance.
Thanks in advance.
