user 37518 said:Do you mean a 10K resistor on the secondary reflected back to the primary at 100 ohms?
ruffrecords said:No, I mean 100 ohms source at the primary reflected to the secondary as 10K. This is the main noise resistance seen by the op amp. The secondary would probably have a 100K resistor across it so when this is reflected to the primary it looks like 1K so as not to load the 100 ohm source.
I know you are thinking the secondary now has a noise resistance of 100K but it doesn't. The 100K resistor is in parallel with the 10K reflected from the primary so the noise resistance is just under 10K.
user 37518 said:Ok I get, what I dont understand is, how if a 10K resistor is reflected to the secondary, how does it reduce the noise as you mentioned? or is it that input of the transformer (the primary) should be considered as the input resistance to which EIN is refered?
NF curves are generally published for discrete (low noise) transistors. Op amps generally publish ein noise voltage and noise current specs.user 37518 said:Makes a lot of sense, do you happen to know where can I find the 5534 graph which displays what you are saying, in the data sheet theres only the one I posted in my first post and doesnt follow the parabolic response you are refering to.
