xaxxon
Member
Depending on what schematic I'm seeing, either r7 is fixed at 2.7k, or varies between 1k and 2.7k.
r25 can vary between 27k and 100k, with both resistors seeming to relate to the T4B.
I'm not quite grasping the variance, since the factory would be using a uniform part (I think?).
Could somebody give me guidance as to what values I should use, based on which aftermarket T4B I would use (if that's significant)?
