Adding panpots to tube Raytheon console
BossOrgan
Member
Hi all,
I'm a new member here, but i've spent many hours reading this forum over the years. Great source for info, thanks!
I'm starting the process of rebuilding/converting a vintage Raytheon RC11 tube broadcast console into a 9x2 tube mixer. It originally is a "dual" mono console, each channel has a switch to send the audio to the program or the monitor amp, or off (center position).  I want to replace these switches with a NewYorkDave style panpot, to convert the program/monitor amps to "left/right". I am not sure what impedance/resistor values I should be shooting for. Each mic preamp has a plate to line transformer feeding a 500ohm daven attenuator, and then a 470ohm mix resistor feeding the mix bus. Input for the program/monitor amps are 500ohm line to grid transformers.
Any ideas on the best value for the panpots? I would like to remove the 470ohm mix resistors (and switches) and replace them with the NYD panpot circuit.
Attached is a schematic for the RC11.
Thanks!!!
Tyler
This may be difficult. This is a typical 'constant impedance' mixer. When an input is routed to a bus it is fed through a resistor to the bus. When it is deselected it is replaced by a resistor of the same value across the bus so you cannot just change the value of the series resistor as in the NYD pan circuit. Also, the existing switch system connect and input to one bus OR the other. A pan pot need to connect the signal to both buses and I am not sure if you can maintain the constant impedance to both buses as the pan operates and also not overload the channel amp.
It probably can be done but it is not as straightforward as you might think.
What Ian said.  Any impedance change from any channel will make overall gain and mix swim up and down with the change.
I honestly don't think it's worth the work for the limited value gained, and the value hit on the console either, unless the console is truly trashed.  You may be taking value off for the next guy down the road.  All the guys I have set up with consoles like this want them as original as possible.
And, the console isn't dual mono with 2 of the same output amp either, unless you're telling me the output transformers are the same, and only the output tube configuration is different.  You can do that with two different amps, but it's not an entirely matched sound or setting.
If the switches have enough contacts, you can go LCR, try to find Altec 250SU or T3 documents.  Those are the only old consoles that even did that, everything else was mono or dual mono.
When panning was done then, it was a Daven or Langevin type ladder pan pot, essentially a dual Ladder designed to maintain impedance no matter the position.  No stock console was ever built with a full array of those, nor with even a few.  Customs may have had one or two on a patchbay for custom assignment.  You could probably do a simple version of that as a best case, maybe 5 position.  Ton of work.
Thanks for the thoughts guys.
I could sacrifice one of the mic preamps as the "center" make up gain stage amp like Altec 250SU... and setup the switching for L/C/R.
Here's another idea: The output transformers for the channel amps have a dual secondary. I could split up that secondary into two seperate outputs, and add in 7 more 500/500 ohm davens, and have L/R volume controls for each channel. However, this would change the impedance reflected to the 6J7 tube, and lower the output gain..... so I dont know how well that work. Plus i'd have to source those davens. Thoughts?
emrr, you are correct that the the two output amps are slightly different, one has output wired as triode and the other as pentode, and have different output trannys. The specs for gain and frequency response in the manual for the two different amps are very close however, so I am not going to worry about it. That will add a little extra "flavor" into the mixes!
I have not been able to find NewYorkDave's .pdf about his panpot design. Does anybody have it? I would like to read it.
Thanks again,
Tyler
I guess the big question is how many pan positions do you need. If you need a continuous pot then it is not likely to be possible. If you just want LCR and a step each side between these two then it might be possible with some rotary switches.
That's a better idea than many, if you're drilling the face.  Sourcing those Davens currently at least is cheaper than the parts/labor of wiring up pan pots that'll work.  Those preamps are 30dB at most, maybe less.  I don't think you take much of a hit doing that.  If I follow the ratio correctly, splitting up the windings changes it to a pair of 125R windings, so each then is driving a lighter load.  I think it mostly comes out in the wash.  You can then lose all the switch loading since it's no longer needed, and the switches.
The Altec LCR switching plan means replacement of some of those switches too, there aren't enough contacts on all of them.  I think I'd add another center  buffer amp somehow rather than giving up an original preamp channel.  Only a slight hit on Fil/B+ requirements.
I was thinking: cut the middle out, route out to a $200 8/2 line mixer and back.
Thanks again for the replies.
I have found one 500/500 Daven locally. I will try splitting the output tranny on one channel and wire up a daven for each side. Will report back on how it works....
-Tyler
PRR, that's certainly a solution that would work.... but the whole point with this console is to not use transistors or opamps... all tube. :)
Hi again!
I'm not trying to be annoying or sound stupid, but I am still trying to figure out why the NewYorkDave style panpot will not work with this mixer. It took me a while, but I finally located the schematic for NYD 600ohm input/output passive mix and pan circuit. It seems a bunch of folks have built and use this circuit to mix 600 ohm line sources together and feed it to a 600ohm preamp as make up gain. This is exactly what i want to do with this Raytheon RC11 (well the raytheon is 500ohms but thats close enough i think). The NYD circuit uses a 1k pot with slugging resistors as the volume knob for each channel, feeding a 1k input resistor to a 5k linear dual-ganged panpot with a 2.5k slugging resistors, feeding 3.9k mix resistors to the mix busses. This is unbalanced. I would like to use this circuit, but instead of the 1k volume pot with slugging resistors, use the existing 500/500 davens. The big difference is the RC11 has the input transformer for the program/monitor amps (which would be the Left/Right amps in my case) wired for 30/50 ohm input, and uses 470 ohm mixing resistors feeding it for the constant impedance topology. These input transformers have multiple primary windings, and I could rewire them for 500/600 ohm input impedance instead, which would match the NYD circuit for output impedance.
Seems to me this should work fine, but apparently I am missing something...??  As I understand it (from my calculations) the impedance on the mix busses doesnt change all that much with the panpot.... when a channel is panned hard left or right, one bus sees a 3900ohm load from that channel, while the other bus sees a 4582ohm load. When panned middle, each bus sees a 5079ohm load. Now keeping in mind that the panning for each channel would normally be "Set it and dont change it" (for a particular mix), this slightly changing impedance seems like it wont matter much in terms of the interactivity of each channel.
Everybody's thoughts are appreciated!
Thanks again
Tyler
Don't change the PGM amp wiring, convert one PRE channel, and report back.  Maybe it's fine.  PGM is open grid.  To a large degree, any losses from a lower bus output Z are made up by the additional transformer gain.  Looking at other similar consoles, some others are 600R busses feeding 50 ohm windings; consider the parallel R aspects here.
Did the dual ladder experiment happen?
Thanks Doug,
I am still rebuilding the console (first, before I start modding it), so havent done the dual ladder test yet. But while doing the rebuilding I am trying to come up with all my options as a game plan for the mods.
My ideal situation would be to have single volume knob for each channel (as opposed to the split windings/two davens for L/R), and the panpot instead of just L/C/R switching. I still want to split the windings on each channel amp, but one winding would be for feeding the L/R amps and the other would feed a (switchable) direct out or an echo out bus. I would install a 6sn7 preamp for the echo out bus, and use the original program/monitor switches to switch between the direct out/echo out. So really it would be a 9/3 mixer.
Maybe i'm dreaming too big.
I am building out the case 3" on the bottom with some J channel aluminum, where I will mount all the connectors on the back side, and the various extra switches etc on the front side. Have a nice amphenol plug to connect the power supply to the console. Basically it will be "portable" (haha) instead of being hardwired to a patch bay etc. I plan to use it with an 8 track tape machine.
Thanks again
Tyler
You should just sell a kidney and buy my BC-2B, it's already done!  : )  Wait, what's a kidney go for again?
I like this idea for direct out, not certain it proves reliably isolated, or not.  Echo bus mods tend to be a bridging Hi-Z pot off the main feed, into said bus.  Looks like the early UA consoles did this too.  The tube Neve I worked on did as well.  Not sure you need to be either/or about direct out and echo.
The big difference between your mixer and the NYD circuit is that NYD's design is intended to be driven by low impedance sources that are capable of driving a 600 ohm load. Their output impedance is typically a few tens of ohms and I think this is an assumption of the design. Your mixer channels have an output impedance that is 600 ohms so it may be too high for the design to work properly. Without the schematic it is hard to tell for sure.
Someone should link the specific NYDave plan and comments.  I came up with 3 different ones when I looked.
I posted the schematic for the RC11 in the first post.
Here is the schematic for the NYD circuit. I know he had taken this down from the web so my apologies if he doesnt want it reposted. Wherever NYD is, thank you for your ideas!
You know, I think that will work as it is. I was always impressed with the subtlety of NYD's designs and this one is no exception.
