THAT 4320 "One Knob" circuit GR metering
OneRoomStudio
GDIY Supporter
Minneapolis, MN, USA
I need a sanity check - I'm designing a circuit that incorporates a section similar to the "one knob squeezer" in this application note: http://www.thatcorp.com/pedals/4320%20Battery-Powered%20One%20Knob%20Squeezer%20r00.1.pdf
I'd like to add a 1mA GR meter, but I want to make sure I'm putting it in the right place. I should just be able to hang it from pin 3 of the 4320 to ground right? I'd probably add a series 4k7 trimer like in the GSSL. Is there any reason I'd want to connect it elsewhere or buffer it or anything? Thanks!
