2sk1019: any use for?
> Any uses?
Pass-device for regulating to 40V-300V outputs. Pick a Zener(s) about 4V higher than the desired voltage, a resistor to flow a few mA through the Zener, and tie the FET gate to the Zener.
Kind of a lot of input capacitance for an audio amp smaller than 100W, and audio amps like complementary (P-type) devices.
If you have a 1960s Ford: a few dozen of these FETS in parallel plus a 9V battery can replace the sticky starter relay.
Thanks PRR.
I was hoping for a DIY audio use, but, oh well.
Anyway, I've got a buttload, so if anyone has a Ford with starter relay issues...
Jeff
