muzikliberated
Active member
- Joined
- Mar 7, 2013
- Messages
- 33
Hey Again,
I'm now working on audio routing for my synth project and wanted to run this past you.
I am using a shift register to control a pair of 4067 16 channel analog multiplexers.
Schematic attached.
The circuit is supposed to take the output from each voice and of course route it to different physical outputs.
I'm not sure if the audio signals going into the multiplexer needs to be pre-attenuated and then amplified again on the other side, I read somewhere that the IC will saturate.
thanks
Schematic attached.
thanks
