Electret mic capsule isolator
JAY X
Hi all,
I'm looking for an electret mic capsule isolator, as i don't want chassis connection. Because i connected the gnd capsule to circuito gnd.
Does anyone know where i can find 10mm round capsule chassis isolator??.
Thank you for tour help!!
Jay x
I have a Glendale talk back module that uses an electret. The capsule has a thin piece of foam rubber glued to the front. The other side of the foam is the glued around the hole on the front panel that you talk into.
