Tube testers basically need to apply voltages to each electrode and measure some other current. So you can measure most things with a few pots, a few meters, and a big switch to move the meter function to different points in the circuit. You'll need to measure grid and plate currents, voltages, and set grid (each of them) and plate voltages easily. Follow the qualification test specifications you see on the Ratheon military tube data sheets - they show leakage currents, noise, etc. tests.
